Heater Advice
Old Jan 17, 2007 | 03:43 PM
oarhead61's Avatar
oarhead61
Heater Advice
'91 f150- 4.9. I have read through the threads and believe my lack of heat stems from the blend door (fingers crossed). Warm air at best, no heat to the floor, both hoses to the core are hot, etc. I took off the glovebox door and am looking at 7 maybe 8 screws. I assume this is how I would access the problem. Do I have to remove the heater core? If I do I may as well change it. I am also confused as to where the vacuum lines are located and exactly what affect they could have on my problem.
Also was wondering if a fluctuating temp gauge is normal for these trucks. Mine goes from just past the "c" to just past the first line in the normal range and goes back and forth during highway driving. T-stat new, coolant all set.
Any help or advice is much appreciated.
Oarhead sends
Old Jan 17, 2007 | 03:46 PM
quicklook2's Avatar
quicklook2
mark which hose goes where before you remove them.
remove cover, than core and you will be able to see everything move or what caused problem.
bet it is a pen.
Old Jan 17, 2007 | 05:38 PM
mrl390's Avatar
mrl390
I dont know about the 4.9 but my truck with a 5.0 runs on the O in normal and stays there. Seems like you're running a bit cold. Try replacing the thermostat before you tear out your heater core.
Old Jan 17, 2007 | 10:58 PM
albung's Avatar
albung
just changed mine (thermostat ) i got lil heat at best im bout to pull fan...motor barely gets hot i can hold hoses with bare hands
jcstu
18
Feb 9, 2015 11:25 PM
jagger blaze
1997 - 2003 F150
Nov 18, 2014 09:40 PM
rhu05
Dec 22, 2010 05:04 AM
sc93f
Feb 13, 2004 09:54 PM
mhjohnson48
Jan 6, 2003 06:49 PM
