Sponsored by: Real Truck
Help!!
Old Jan 16, 2007 | 10:03 PM
ilo9's Avatar
ilo9
Help!!
I have an 04 KR f-250 with 6.0 diesel. I have an oil plug leak. I changed the metal washer around the plug. I was told to go up one size wih the plug because the hole is worn out. I was also told to clean the existing plug and use thread locker to seal it up. Have any of you dealt with this. What do I do? Is it enevidible I will have to replace the pan?? I drive this truck all ove the planet for work and can't deal with knowing there is a leak no matter how small.
Old Jan 16, 2007 | 10:05 PM
RJB1's Avatar
RJB1
buy a fumoto valve and seal it tight. then you will never have to un screw it again...
Old Jan 16, 2007 | 10:08 PM
ilo9's Avatar
ilo9
Where do I get one? How do I put it in?
Do stores sell that Like Pep Boys?
Old Jan 16, 2007 | 10:23 PM
RJB1's Avatar
RJB1
I ordered mine on line (google it) it replaces your drain plug. It works great!!! I'm sure others will chime in and agree with me.
Bob
Old Jan 16, 2007 | 10:46 PM
biz4two's Avatar
biz4two
Arrow
The issue now with going to a Fumoto valve is the fact that the oil pan has been used with an over sized plug.
Not sure who told you that the oil pan hole was worn out, but that does not sound logical. Heck your SD is only an '04. Maybe the treads were crossed or something once. The metal washer should be replaced at each oil change.
IMHO...You need to replace the pan and then install the fumoto valve.
Good luck...
biz
Old Jan 16, 2007 | 11:03 PM
RJB1's Avatar
RJB1
I would agree, if the plug won't seat tightly. but first I would probably try installing a Fumoto with teflon tape and a new gasket.
Old Jan 16, 2007 | 11:05 PM
69cj's Avatar
69cj
I have seen the drain plug cross threaded and replaced the plug and everything was O K. Try a new plug first, they are cheap. If it doesn't leak then get the Fumoto. You have nothing to loose considering what it takes to change the pan on a 6.0.
