Sponsored by: Real Truck
Emergency Brake
Old Jan 16, 2007 | 08:56 PM
KGB's Avatar
KGB
Emergency Brake
Does Any One Know How To Tighten The Emergency Brake On A 99 250 Sd. Xlt 4wheel Disc Rear Abs
My Machanic Said He Tighten It But I Can Still Drive Off With It On And The Alarm Does Not Always Go Off When I Drive With The Brake On .
Thanks
Old Jan 16, 2007 | 09:07 PM
bones318v8's Avatar
bones318v8
go up under the truck and look for the cable going up to the front ,follow it back where it has a bracket like thing where one cable ends and another continues you should find a bolt that you can screw inward to tighten it up or another is to look around the rear axle it maybe on top of the axle to tighten it up , if not I will find out more for you!!
Old Jan 17, 2007 | 10:11 AM
KGB's Avatar
KGB
I Know About Cable Bracket Goes From One Cable To Two Cables For Rear Wheels .
I Just Was Not Sure If That Was How To Ajust Brake There Or If It Was Something Like Drum Brakes W/screw Driver And Star Wheel In Side Drum And Had Some Ajustment On Caliper.
Thanks For Info I Will Look At Truck To See
Old Jan 17, 2007 | 07:51 PM
bones318v8's Avatar
bones318v8
thank you for listening and being a true blue ford buddy!!
