Leaking OIL!
Old Jan 16, 2007 | 08:03 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
Unhappy Leaking OIL!
Help, just put intake/exhaust, glow plugs and Edge programmer on a 95 7.3, 4x4 CC w/312k miles I drove it back to the guys house Sunday, all good, he drove it monday and tuesday, now has an oil leak on drivers side, NOT from valve cover, what is a common leak???? on this side of the engine
Old Jan 16, 2007 | 08:25 PM
Dick7.3's Avatar
Dick7.3
you check thr oil cooler?
Old Jan 17, 2007 | 09:39 AM
Pickupmanx2
I am gonna go wipe it down and check it friday,,,,,aarrggghh
Old Jan 17, 2007 | 09:05 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Is it coming from the front or the rear part of the engine? If it is the rear, i had a truck i worked on, where the actual rear header casting for the oil cooler had a pinhole in it that was invisible to the naked eye. Pressure test showed the leak. I had to buy a new header for the guy. It looked as if the oil was leaking out of the gasket that seals the header to the block.
Old Jan 21, 2007 | 10:29 AM
Pickupmanx2
Turned out to be the oil cooler, he had driven it, the day before, then I went down first thing in the morning, steady stream right out of the front.
Asytole61
Nov 22, 2014 05:17 AM
mavman
22
Jun 5, 2011 02:11 PM
mexicoF250
Apr 13, 2010 01:09 PM
orange_x_crush
Sep 6, 2008 04:00 PM
kro4
Dec 3, 2005 07:53 PM
