Hard starting die.
Old Jan 16, 2007 | 01:13 PM
Hard Luck's Avatar
Hard Luck
Cool Hard starting die.
Hello Hard Luck Hear. I have a 1993 f350 reg cab die. eng. I have recently experienced major trouble cranking it. I have replace all but 2 of the glow plugs those under the fuel lines from the injector pump. I will change these, as i read that 1 or two will cause a problem. The thing i want to know about is when i tested the voltage to the glow plugs the test light light up the first three time the regulator clicked and then it just faded away in the next 2-3 clicks. The reg kept clicking for about 30 seconds or so but the test light never came on again. The wts light come on but only for 2-3 seconds and this is random at times. Since i changed the 8 of the glow plugs (they have never been changed) it cranks some what easier but you still have to try two or more times. I do not have to use any either to assist now. Is the controller bad/ or the water temp switch bad. I do i ck them? I really love the old truck and it has many more mile left in it but hard starting is getting old. Our weather hear has not bee cold at all 50-60 deg most of the time. Any one have any suggestions?
