whistle
Old Jan 16, 2007 | 01:33 AM
tutivaz's Avatar
tutivaz
whistle
I have a 1995 turbo diesel.It hav a loud whistle when it starst to go.At Idle its fine but if you accelerate it appears.When you drive it doesnt go over 30 mph but after a few miles the noise stops and works fine.Next when your on the freeway all of the sudden you lose power.then it regains power.Could it be the turbo,or the trans.
Old Jan 16, 2007 | 05:48 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Does it only do this while it's cold? If so it's probably your EBPV (Exhaust Back Presure Valve). Try unplugging it, a two wire connector under the turbo.
Old Jan 16, 2007 | 10:09 AM
johnstoys2's Avatar
johnstoys2
Check your air intake clamps & hoses after the turbo. it's posible the clamps are loose letting boost air past the hoses. When I worked on the big trucks the turbo would spool up ( making about 30 psi of boost) & the clamps would break. It would sound like a shotgun going off followed by a severe lack of power.
