4x2-4x4 swap.
Old Jan 15, 2007 | 09:48 PM
wozxxx86's Avatar
wozxxx86
Question 4x2-4x4 swap.
ok i know people have done this. i swap my e4od to an older style aod '88. is there a way to get the backup/neutral safty switch to work? or is it possible to make a 2wd e4od a 4wd tranny?will a 1356 tcase bolt to it? the reason for this swap was that i wanted 4x4 and the e4od wasnt shifting out of 2nd unless u let off the gas. now my aod is acting up and thinking about swaping back if i can still make it 4x4. if i can get my aod to work without a rebuild i will stick with that, hence the first question
thanks aheada time
