power steering problem
Old Jan 15, 2007 | 07:55 PM
Tuff48's Avatar
Tuff48
just got the truck back from getting my pcm fixed where I shorted it outand now my power steering is whining. its really bad at slow speed turns. and when idling in neutral if i press the brake it whines also. from what ive searched the brakes and power steering are tied together. is the power steering pump the problem? 99 f350
Old Jan 15, 2007 | 08:06 PM
Uzumati's Avatar
Uzumati
Could be, is the fluid level good?
Old Jan 15, 2007 | 08:12 PM
Tuff48's Avatar
Tuff48
yes the fluid level is good. at first thats what i thought, my 78 4x4 f150 makes the same whine when it gets low i know it leaks, but there is no sign of leaks on the 99. is there a booster on these pumps
Old Jan 15, 2007 | 08:19 PM
Uzumati's Avatar
Uzumati
No PS Booster but the power steering pump is also tasked with supplying the Hydo Boost for the brakes. You can try a flush and fill it may give you a little longer life.
https://www.ford-trucks.com/forums/4...steering+flush
Old Jan 15, 2007 | 08:23 PM
Betthebux's Avatar
Betthebux
What I did was suck out enough fluid to add a bottle of STP engine treatment. I have read on here where it might help. So far (about 2 months) the whine has not returned.
I had done a flush with syn. atf about a year before this.
Old Jan 15, 2007 | 08:47 PM
Tuff48's Avatar
Tuff48
thanks ill try the flush. what damage would it do if i continue to drive before i replace it or give it a flush? is the stp better than the atf.
Old Jan 15, 2007 | 09:02 PM
Uzumati's Avatar
Uzumati
ATF is what the pump requires as fluid. Some people get good results from putting additives in the fluid.
Old Jan 15, 2007 | 09:26 PM
Betthebux's Avatar
Betthebux
Flush with syn atf first. If you still have the whine you might want to try a bottle of STP engine treatment (the honey looking stuff)
Instructions for flush here in post 9
Old Jan 18, 2007 | 07:00 PM
Tuff48's Avatar
Tuff48
bettthebux,amiller93 Fellows thanks for the info. i flushed the pump and put new back in and its working pretty good. you guys saved me some moolah
Old Jan 18, 2007 | 07:40 PM
Uzumati's Avatar
Uzumati
Good to hear it tuff, good feeling when ya "git er done" without a labor fee
