Overboost Anninhilator
Old Jan 15, 2007 | 03:32 PM
hdman6's Avatar
hdman6
Question Overboost Anninhilator
Anyone have the overboost annihilator for ITP deisel? I see it listed and I am not sure if I will need it or not. Here is my set up :2002 7.3 crewcab sb. I have installed the AIS severe duty air intake witht he foam fender mod, I am installing the guages now (boost, pyro,trannytemp) and just ordered a 4 in SS mbrp turbo back exhaust. I plan on a DP tuner chip with the norm 20,40,60,80 econ and 120 hp. (not sure exactly what ones yet, need to talk to jody) But will I require a overboost kit like ITP sells? thanks Jeff
Old Jan 15, 2007 | 03:35 PM
Badluck's Avatar
Badluck
yes you will need it... I dont have that one specifically but i had the sp diesel overboost eliminator... there are other ways to set up an OB elim but I figured this was the easiest, this is so you dont throw codes and defule when you hit more boost than stock with your new chip
Old Jan 15, 2007 | 04:24 PM
CSIPSD's Avatar
CSIPSD
The only thing I dont like about the SP Diesel kit is it doesnt let the truck see the corect boost at any level, the ITP kit does up to 22#'s
Old Jan 15, 2007 | 04:35 PM
hdman6's Avatar
hdman6
Question
Iam interested in the ITP overboost they sell, I see they have install sheets for an overboost kit but I cant seem to find that "kit for sale. I only see the overboost anninhilator. And can someone tell me where this is installed? and does it work well? thanks I am looking to puschase soon because i will need something for the overboost from what I hear. thanks jeff
Old Jan 15, 2007 | 04:36 PM
Bin Strokin's Avatar
Bin Strokin
is there a home made way to make a overboost eliminator, is there a valve i can buy or something.
Old Jan 15, 2007 | 04:42 PM
ryaneverk2's Avatar
ryaneverk2
Yep, you'll need one of these once you get the chip from dp-tuner. Here's how it looks once it's installed:
http://rides.webshots.com/photo/2824...86590301BpoLst
It takes about five minutes to install and works tremendously well. I'd recommend this over any other overboost device.
And to Bin Stroking, some folks have made their own using a regulator from a hardware store and fabbing one up, so it is certainly possible to create your own.
Old Jan 15, 2007 | 04:53 PM
ron's power stroke's Avatar
ron's power stroke
i use this one..no problems yet.ive pushed 27 to 28 lb boost and no ses light...it has a hole for the boost gauge for the turbo.. and a extra hole for a gauge to show what the pcm reads..it will show 22 to 23 all the time to the pcm..http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=31
Old Jan 15, 2007 | 04:59 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Get the ITP:
Old Jan 15, 2007 | 05:00 PM
Fire Rooster's Avatar
Fire Rooster
I use ITP's it is great. Easy to install, fast and works fabuloso
Old Jan 15, 2007 | 05:01 PM
guzzle92's Avatar
guzzle92
I'll have to throw my hat into the ring with ryan, RAMPAGE and Fire Rooster. There is no better boost code eliminator than the regulator like the one from ITP Diesel.
I have yet to have anyone give me an explaination I'll buy that a relief valve is any different than a boost leak at a boot connection.
Old Jan 15, 2007 | 05:05 PM
Fire Rooster
One note I forgot. DO NOT mess with the regulator **** when you get the kit. Dennis has then pre-set at 21psi.
Old Jan 15, 2007 | 05:21 PM
skuteman's Avatar
skuteman
......................I purchased the ITP unit from DP tunner at the same time I ordered my chip and it works very well and is relatively easy to install . I'm pulling a 14k fiver and haven't had any problems yet . sk
Old Jan 15, 2007 | 05:28 PM
CSIPSD's Avatar
CSIPSD
I used to have that one and kept setting a SES light... went with the ITP kit and picked up about 2#'s boost on the gauge at WOT...
Old Jan 15, 2007 | 05:32 PM
ryaneverk2's Avatar
ryaneverk2
Good point... I do think the install. instructions that come with it point this out, as well.
If one were to happen to mess it up, they could send it back, and Dennis would reset the regulator to the proper level.
Old Jan 15, 2007 | 07:16 PM
Kwikkordead's Avatar
Kwikkordead
Another vote for the ITP regulator.
Rampage that picture you took could very well be the one under my hood, it's mounted exactly the same.
