Sponsored by: Real Truck
over heating
Old Jan 15, 2007 | 01:42 PM
tradesman's Avatar
tradesman
over heating
Good morning everyone. My 95 F250 is overheating for a few min then cools off, then repeats. Also, my heater blows cold while it is hot. Anybody with suggestions on what might be wrong?
Old Jan 15, 2007 | 01:46 PM
GoldenDually's Avatar
GoldenDually
Bad Thermostat.
Old Jan 15, 2007 | 06:56 PM
ohboy44's Avatar
ohboy44
Bad T-stat and or low on coolant.
Old Jan 16, 2007 | 08:05 PM
tradesman's Avatar
tradesman
Thanks. I was thinking of the T-stat. The coolant was also low.
Old Jan 17, 2007 | 06:04 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to FTE...and moved to SD...enjoy!
Old Jan 17, 2007 | 08:09 AM
redford's Avatar
redford
Hi Tradesman! Welcome to FTE.
Low coolant will also cause the symptoms you desribe. Before you replace the T-stat, top off the coolant. If you still get overheating and cold air, the T-stat needs replacing. If everything is normal you get to find a coolant leak.
Old Jan 17, 2007 | 08:20 AM
Ben-jamin's Avatar
Ben-jamin
fill up the coolant then test the system, give it time to work the air out. If coolant doesn't touch the thermostat a new wont work either. Get a heavy duty or motorcraft, they seem to yeild the best results (if you have to replace the unit)
