NEEDED - Driver side extended cab corner
Old Jan 14, 2007 | 10:22 PM
broke33's Avatar
broke33
I have a 1991 F150 with an extended cab that need the complete cab corner from the door jamb (even part of the door jamb would be nice) over to the rear of the cab. I need at least 20 inches up from the bottom. Anyone have an old truck laying around they can cut this section out for me? Im in the Detroit area and would be interested in buying whatever comes close tot his.
Thanks alot!!
Old Jan 14, 2007 | 10:35 PM
quicklook2's Avatar
quicklook2
go to list of sponsers and click on national parts depot or bronco junkyard.
posting your phone number is a no no.
Old Jan 15, 2007 | 05:17 AM
broke33's Avatar
broke33
Thanks for the help, but these places only sell replacement panels with a maximum height of 17 inches and it will not cover any of the door jambs. Ford used to sell a complete cab corner that went up to the roof, but they discontinued this a few years back and no dealships have it. This is something that will need to be cut off an existing truck.
Old Jan 15, 2007 | 06:49 AM
cradar69's Avatar
cradar69
Take a look at JC Whitney. Believe it or not they have quite an extensive selection of body parts for older vehicles. Other than that try a junk/salvage yard. Good luck.
Old Jan 15, 2007 | 08:24 AM
broke33's Avatar
broke33
Yes. JC Whitney does have a HUGE selection of parts, but they are also limited to 17" maximum height on their panels. I have tried the local junk yards, but Im in Michigan and everything I have found here has rot. I was just hoping maybe someone had something laying around that they are going to get rid of that I could get the corner off of it.
Old Jan 15, 2007 | 11:37 AM
jk89cat's Avatar
jk89cat
you can still order one for a 92-96 from ford but i warn you they are not cheap
Old Jan 15, 2007 | 12:52 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Posting of phone numbers is a personal thing, I personally would not suggest it....however ....
Old Jan 15, 2007 | 01:07 PM
lostin90s's Avatar
lostin90s
There are lot in wrecking yards down my way but you will end up fixing skin on it(rust ). If you end up having to ship something of that size might be as cheep to buy parts truck . I used to get parts out there and haul home ( Big city cheep parts)when I drove truck can't believe you cant find what need in the area. I know of 6-7 different yards.
Old Jan 15, 2007 | 02:24 PM
broke33's Avatar
broke33
I got a call from a local guy who is going to cut a corner off a truck he is junking. Thanks for help. This forum sure gets alot of attention. Great place to ask for help if needed.
Thanks again
