Blend door fix question
Old Jan 14, 2007 | 09:05 PM
TommyDee's Avatar
TommyDee
Question Blend door fix question
How far down the pin from the actuator should the hole be drilled? If the actuator doesn't go fully onto the mounting studs, do you drill the next hole further up or down the pin from the original hole?
