Diesel Slushee
Old Jan 14, 2007 | 12:56 PM
bigcountry560's Avatar
bigcountry560
Diesel Slushee
I had just left the house and the truck was noticable down power and then I noticed I didn't have any fuel pressure. I flipped around back to the house and started lookin for the problem. I found my Dahl filter frozen. Right now it is -5 here in NE Utah. After draining the fuel bowl and what was left in the tank (luckily not much), and bypassing the Dahl filter, I was able to get fuel pressure and the truck is running fine.
I had put myself in a bind and had to fuel up at a place I normally wouldn't. Just more reason to know where to get fuel, and not from places who don't go through much and don't have facilities for semis. Also, the fuel gauge in the cab was an expensive investment, but it saved quite a bit of time in troubleshooting.
[img]file:///C:/Documents%20and%20Settings/mtyndall/Desktop/100_0412small.jpg[/img][img]file:///C:/Documents%20and%20Settings/mtyndall/Desktop/100_0412small.jpg[/img]
Old Jan 14, 2007 | 01:01 PM
guzzle92's Avatar
guzzle92
I knew there was a reason I added DK to every tank.
Old Jan 14, 2007 | 01:02 PM
BuickTurbo's Avatar
BuickTurbo
Wow...that's a nice lawnmower.
-5 will gel fuel for sure.
Old Jan 14, 2007 | 01:08 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Damn, Dan as i was looking at that first picture i was going to comment on the lawnmower too. If that was 100% biodiesel i would have been tempted to put some in a glass and eat it. I don't think it would be bad either. Were you running any additive? With temps that low i would run a tank heater!
Old Jan 14, 2007 | 02:05 PM
hosemandc's Avatar
hosemandc
Is that a stock water seperator or aftermarket. I have yet to find or mess with mine. I had the dealership change mine last time, but I would like to do it on my own next time.
Old Jan 14, 2007 | 02:31 PM
John311t's Avatar
John311t
I think you need some anti-gel additives.
Old Jan 14, 2007 | 02:33 PM
John311t's Avatar
John311t
That would be an after market one. The stock water separator is where your fuel bowl is on the top of your engine where you put the fuel filter in.
Old Jan 14, 2007 | 02:34 PM
guzzle92's Avatar
guzzle92
That's a Dahl 100 aftermarket filter. It is normally used as a pre-pump filter in conjuntion with the in-tank modifications to remove air in the fuel lines.
Old Jan 14, 2007 | 04:33 PM
ron's power stroke's Avatar
ron's power stroke
that one needs to sit on a shelf with a wic in it....that sented candel will burn for hours..
bailegb
Sep 3, 2010 11:21 PM
Scratcher
29
Jun 3, 2010 06:06 PM
reed1951
May 6, 2009 11:13 AM
sglynx1
Nov 21, 2006 01:26 PM
habby19
13
Mar 23, 2006 11:21 AM
