random stalling
Old Jan 14, 2007 | 09:26 AM
84f250460's Avatar
84f250460
random stalling
it seems that randomly at stops the truck stalls as if i just turned the key off. motor just dies, press the clutch and turn the key. away she goes. the idle also seems to constantly be changing? anyone have any ideas?
Old Jan 14, 2007 | 04:58 PM
ReAX's Avatar
ReAX
Sounds a bit like IAC, but the hunting idle in my 89 4.9l was cured by cleaning the backside of the throttle body. I would say, pull the throttle body and IAC valve; spray them off with carb cleaner and wipe down.
Old Jan 15, 2007 | 03:54 PM
84f250460's Avatar
84f250460
mines not FI its carbed
Old Jan 19, 2007 | 04:22 PM
grifster's Avatar
grifster
Have you tried adjusting the carb with the little screw on the side. This will change the gas-air ratio and may help. If you have tried this, perhaps the screw is coming loose with driving.
Old Jan 19, 2007 | 05:33 PM
havi's Avatar
havi
I'll have the Roast Duck
also look at the little linkage rod hanging down in the front(facing grill). Mine popped out of the slide and caused mine to die upon sharp turns.
