52 flat 8 oiling system
Old Jan 17, 2000 | 08:14 PM
Marvin's Avatar
Marvin
Howdy folks;I have just started to restore my 52F-1.Since this is my first flat 8 I am learning about them.Seems to me the oil filtering system sucks.Is there an easy way to convert to full flow system,mine has only one line going in and no out.Can you run a line out the bottom plug of the cannister and drill a hole in the stem in the can,then run the line to the 1/4 plug on the left lower side of the block. Or is there pressure behinde this plug.I have seen the after market system where you put a fitting through the pan and use spin-on filters but I would like to keep mine stock.Thanks for any help.
Old Jan 19, 2000 | 06:55 PM
Jim_V's Avatar
Jim_V
MustangMatt96GT
Feb 19, 2011 11:38 AM
oreocreaming
Sep 19, 2010 05:02 PM
SCROWLEY707
17
Mar 9, 2010 02:08 PM
luvemhot
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 28, 2008 12:41 PM
