Yet another question re true duals
This is my first post but I have been lurking for weeks trying to find more info. Hopefully I missed something; here goes. I have a 94 F150 with the 351W, 4x4 Automatic. Standard bed, and one of those slightly extended cabs; still only two door. Dual gas tanks too even though the fuel pump crapped out on the rear. Anyways, I got a pair of hooker headers (full length) with the bung hole for the O2 sensor. I also have 2 brand new Flowmasters that I bought for my 71 Mustang but never used. I cannot seem to find any premanufactured solution for the pipes and H or X piipe to order online. I don't care about the cats but apparently my state does so I'm going to pick up a pair of the cheapest ones I can find that flow good.
So after my long winded ramble, does anyone have any idea of a manufacturer who makes what I need, and where I should look. I spoke with the local shop yesterday and he said $650 if I provide the parts.
I quickly found this , which I know I could get to work, but I bet they have a FORD truck one, if you search hard enuff.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D680110&N=70 0+4294923429+4294922451+40
P.S.S Do the work your self if you can. if your state does not reqiure you to go take a "smog" test every year or 2 to get your tabs, I would personally make it a Cat-less system, but thats me.
Thanks for the responses. Summirt was the first place I looked but I will check out that link you sent me. I could go catless because I have an emissions waiver in CT. for the life of the vehicle. Also, I know the shorty headers would have been less headache but I want to improve low end torque. Add the flowmasters to that and to me, you have a sound that screams Ford small block.
As far as the H or X pipe goes, my main reason for including it is to equalize. I've heard many people were dissapointed with just a straight through setup but please correct me if I'm wrong.
