vacum advance
Old Jan 13, 2007 | 12:07 AM
mudslingur's Avatar
mudslingur
vacum advance
I recently replaced the vacum advance on my 351m because the rubber seal inside tore or something.All i know is that it would no longer work.I installed a new one and turned the adjustment screw 9and3/4 turns out(clockwise) like the old one was.Now the stalling has gone away(the problem that the old one was causing)but i still feel like it lacks power when I hit the gas.Dose it need adjustment.I have no vacum leaks.
Thanks
Old Jan 13, 2007 | 08:24 AM
Mach1s's Avatar
Mach1s
You need to adjust the timing now.
