Strange Stumble
Old Jan 12, 2007 | 08:41 PM
ReAX's Avatar
ReAX
Strange Stumble
2002 F250 5.4L 64k miles.
I changed my fuel filter a couple of weeks ago, and before that it has only had a miss once before. Now, as it did then, it only last a few seconds. However now, it seems as though any time I travel at a constant speed for 5+ minutes, when I come to a stop the motor shakes and is has a slight hesitation. I have put 300 miles on after the fuel filter, so I don't think there is air traped in it.
I haven't check for codes tonight, but the last two times it did this no codes. Motor's clean, fresh oil, new trans fluid.
Old Jan 13, 2007 | 08:18 AM
suzuki0702's Avatar
suzuki0702
its the iac valve. idle air control valve that is...some guys try and clean it..others just replace it...not sure that cost..but almost positve that'll fix your problem!
Old Jan 13, 2007 | 10:11 AM
ReAX's Avatar
ReAX
I cleaned both about 3k ago. I had the manifold off for other reasons and decided to clean it while I had it apart.
Old Jan 14, 2007 | 08:33 AM
LxMan1's Avatar
LxMan1
Have you cleamed the MAF?
Old Jan 14, 2007 | 09:24 AM
ReAX's Avatar
ReAX
Yes about the same time.
Old Jan 14, 2007 | 07:41 PM
redford's Avatar
redford
FTE Leadership Emeritus
Thumbs down
Originally Posted by ReAX
........ when I come to a stop the motor shakes and is has a slight hesitation.
Kind of like maybe the torque converter isn't unlocking?
Old Jan 14, 2007 | 09:06 PM
ReAX's Avatar
ReAX
I had thought that, but the rpms don't drop much after I have come to a complete stop. However, the first time it happened, it continued to shake while driving. I drove a hundred yards and it stopped.
Old Jan 16, 2007 | 09:32 AM
redford's Avatar
redford
At this point check for codes, or better yet pending codes.
Old Jan 16, 2007 | 05:27 PM
ReAX's Avatar
ReAX
No codes, and hasn't done it again yet. Twice in one weekend, then not at all after a 50 mile round trip with lots of time on cruise. It's a phantom.
Old Jan 27, 2007 | 03:44 PM
ReAX's Avatar
ReAX
Not a trans issue. It did it again today at 40mph, decel felt ok, but accel was shakey until around 2300 rpm. I got a place and dropped it neutral, idle to midrange hesitated, 3K+ was smooth and crisp.
While under power my a/f gauge was erratic, normally it bounces lean to rich, but when it was missing the LEDs bounced atleast twice as fast. I haven't been back out to pull any codes yet, I'll check it alittle later.
It didn't clear up on it's own, so I pulled into arbies and got lunch. Came back out the truck fired up and idled/ran smoothly the rest of the way home. It's becoming more frequent so maybe I'll know what is wrong.
Old Jan 27, 2007 | 07:07 PM
LxMan1's Avatar
LxMan1
Sounds like maybe a sticking injector.
Old Jan 27, 2007 | 07:29 PM
ReAX's Avatar
ReAX
I was figuring something on the top end. I don't know why I skipped injectors. Sounds like I need to find a can of seafoam.
Old Feb 11, 2007 | 05:01 PM
ReAX's Avatar
ReAX
Did it again today, still no MIL. However, I had just put a pt of seafoam in the tank and the stumble went away on it's own.
Must be a nasty injector.
Old Feb 11, 2007 | 05:27 PM
ReAX's Avatar
ReAX
Ok, No DTC's. However, I am looking back over an autotap log I made after the seafoam went through the top end. I think I have an electrical problem. Battery voltage is shown to go from 14.1 to 0 and IAT goes from -44 to 66 *F and so does the ECT. It's cool out side but not below 60. It drops instantly, so It might be a glitch in the software, but it's still somewhat trouble some. Any ideas?
Old Feb 11, 2007 | 07:26 PM
LxMan1's Avatar
LxMan1
You might try checking the PCM grounds just to make sure they are good.
DSMMH
Jan 9, 2014 08:38 AM
f350project
Dec 23, 2012 01:10 PM
lv2race
Jul 16, 2012 02:55 AM
Gordon Freeman
Jun 30, 2011 05:57 AM
0gers
May 25, 2010 07:16 PM
