Sponsored by: Auxito
#4 miss
Old Jan 12, 2007 | 07:31 PM
1 good old boy's Avatar
1 good old boy
Question #4 miss
I have antifreeze leaking into the #4 spark plug hole. It's a 98 f150 4.6L 170k. I used an air compressor to blow out the hole but when it runs about 10 min it start missing again. I was wondering if anyone has any ideas? Intake or head gasket?
Old Jan 12, 2007 | 09:25 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
I would look closely at the heater hose above #4 cylinder, it may be leaking onto the coil and seeping down into the plug hole.
I honestly don't think a head or intake would leak into the plug hole... it would leak into the combustion chamber.
Old Jan 12, 2007 | 10:03 PM
firebug8109's Avatar
firebug8109
i agree. I have a 97 with 276,000 and at about 200,00, its did the same thing. It was infact the heater hose. Mine was leaking where the hose goes onto the intake tube. I just took the compression clamp off and put a regular hose clamp on it.....took care of problem.
Old Jan 15, 2007 | 10:31 AM
1 good old boy
Thanks for the info I thought that may be the problem. It's hard to see back there and I watched for a while didn't see any leak. Sounds like a cheap fix I'll start by replacing the clamp. I just wanted to check and see if I was missing anything. Thanks!
Old Jan 15, 2007 | 10:32 AM
1 good old boy
Old Jan 15, 2007 | 02:53 PM
Wilber15's Avatar
Wilber15
It's not the coil. The 98's didn't have coils yet. They still ran wires.... If it was a 5.4L it might have them. Pressure test the radiator system and watch it after u get about 15 psi of pressure for any leaks around that area....
ol74hb
Jan 6, 2009 03:30 PM
O2SLED
Nov 13, 2008 04:56 PM
ultimatereality5
1997 - 2003 F150
Apr 27, 2007 09:10 PM
propellerhead
Dec 19, 2006 05:34 PM
michael44a
1983 - 2012 Ranger & B-Series
Mar 8, 2006 01:46 PM
