Dome lights
Old Jan 12, 2007 | 05:43 PM
LP2's Avatar
LP2
Dome lights
I was wondering if anyone has any ideas what to check next. I found the dome light fuse blown,replaced it ,and still have no dome lights with or without using the manual switch.
Old Jan 12, 2007 | 11:16 PM
afreemanmd's Avatar
afreemanmd
Maybe an electrical short somewhere? that might explain why the fuse blew in the first place... Did it blow the new fuse too? Sorry I can't be any more help than that...
good luck though!
Isaac
Old Jan 13, 2007 | 04:55 AM
LP2's Avatar
LP2
No, it did not blow the new fuse.I read in the owners manual about a dome light relay. I switched it out with one right below it[same part #] still nothing.
Old Jan 13, 2007 | 09:03 AM
XylemXorro's Avatar
XylemXorro
Hve you installed anything on the roof/ceiling? Anything installed before the light problem?
Old Jan 13, 2007 | 02:40 PM
LP2's Avatar
LP2
No new installs on the roof. I did replace the delay accessory relay and now each map light will come on but still no door actuated dome light.
