Oil Burning
Old 01-15-2007, 11:54 AM
makthenif's Avatar
makthenif
makthenif is offline
Oil Burning
Engine is getting some miles on it and is burning a little oil lately I noticed. Any suggestions on an additive or other patch? Thanks
Old 01-15-2007, 12:04 PM
BrianA's Avatar
BrianA
BrianA is offline
How many miles on the motor?
How much oil does it burn?
What weight oil are you using?
Old 01-15-2007, 05:46 PM
makthenif's Avatar
makthenif
enigine has about 88k. burns about a quart ea 2k miles. i use 10-30 weight oil. thanks.
Old 01-15-2007, 06:51 PM
G'sRed99F150's Avatar
G'sRed99F150
G'sRed99F150 is offline
At 88k, are you sure you're burning, and not dripping?
Old 01-15-2007, 09:21 PM
makthenif's Avatar
makthenif
already checked that. no drips or leaks.
Old 01-15-2007, 10:29 PM
BrianA's Avatar
BrianA
BrianA is offline
Wow. 1 qt in 2000 miles does seem a bit high.
BUT, some have similar oil consumption rates on much newer engines and seem to never have any problem, other than just having to add oil.
If you are sure it is not leaking, I'd do nothing.
No miracle in a can is going to "fix" anything.
I can't remember the specifics, but I seem to remember reading that a clogged PCV valve can cause higher than normal oil consumption. Might want to check that.
Absent something along those lines, and assuming you are buring the oil due to rings, or valve guides, I'd just keep driving and add oil as needed.
rollinblackcloud
05-12-2013 10:55 AM
Blake Moyer
1997 - 2003 F150
04-16-2013 11:21 PM
Epd444
12-10-2010 06:24 AM
bassproguy07
01-23-2006 06:50 PM
wisdom565
1978 - 1996 Big Bronco
09-18-2002 04:20 PM
Quick Reply: Oil Burning
