Sponsored by: Real Truck
two speed axile
Old Jan 12, 2007 | 04:20 PM
SPEC's Avatar
SPEC
two speed axile
My 2006 F250 4 x 4 Is sleeping over at the dealers. The noise that I want fixed is. When the truck is cold, when you throttle down as you take off and then let off it sounds like a two speed axile poping in and out.
Also when I was trying to duplicate the noise By putting the transmission in gear
and holding the brakes and pressing hard on the go pedal and the let off the throttle, I get the auful back lash sound. Dealer says normal!!!!!!!!!!!!!!!
Even though I may have rambled here anyoner have a clue to what is wrong.
Truck has 1,300 miles on it
Old Jan 12, 2007 | 07:05 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Greasing the slip joint on the driveshaft(s) will usually take care of this.
Have them pull the differential cover, and use a dial indicator to check the gear backlask. If it is in spec, have them grease all of the U-joints and the slip joint. I'm sure this will take care of it.
Old Jan 13, 2007 | 05:13 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved to SD
Old Jan 14, 2007 | 06:55 AM
SPEC's Avatar
SPEC
The noise is when you let off the throttle . And only when Cold. I failed to mention that the transmission changes in and out of over drive every time you let off the throttle.Dealer thinks a reflash will fix that???? My dealer is way behind in service so I can't say when I will be back on the road
