Mass air conversion
Old Jan 12, 2007 | 02:03 PM
mac888's Avatar
mac888
Trailering
Mass air conversion
I have a 95 f150 351w with a ZF 5speed and I was looking at the ford motorsports mass air conversion kits. The truck kit only goes up to 93 but as far as I know there weren't that many changes between 93 and 95. So i was wondering if this kit will work before i put out $700 for one. Thank you.
Old Jan 12, 2007 | 02:08 PM
Conanski's Avatar
Conanski
You have a 5speed so you could use one of these kits. But before you spend the $$, what mods are you doing or planning to do?
Old Jan 12, 2007 | 09:17 PM
Old_Paint's Avatar
Old_Paint
I thought everything from '94 up had MAF already? Or was that just the 5.0's? Could that be the reason the kit only goes up to '93?
Old Jan 13, 2007 | 03:01 PM
mac888's Avatar
mac888
Trailering
I have the eddelbrock truck upper and lower intake, a comp cam (dont know the number), and soon some alumminum Y40 heads. I think the 351 didnt get mass air until 96 with OBD11
Old Jan 13, 2007 | 07:26 PM
lostin90s's Avatar
lostin90s
I had a 95 F150 new that was't maf but my 94 f150 is . The sensors are all same except Maf and air temp sensor that used to be on intake was moved to air box. Since you have one of trucks that already has air bags ect. Find truck with MAf get harness , ecm ,air box w/ maf you should be good to go. As the 302 changed to 351 firing order you could use everything but ecm off a 302. This could come off and E4od truck as you have to get ecm for manual anywhy. And I know you could get the parts used for alot less then you stated.
