Performance Chips
Old Jan 12, 2007 | 10:25 AM
zss42002's Avatar
zss42002
Performance Chips
I have a 2000 psd lifted 6", and banks power pack package. i was wondering if i can put in the edge chip? will it be compatable with all the other banks stuff or will it be a confict??
Old Jan 12, 2007 | 10:51 AM
CSIPSD's Avatar
CSIPSD
You will need to remove the Banks chip if you have one from the computer. If you are wanting to add the edge ez then it will work, but any kind of programmer, the chip will override. Get a real chip 6 position from Jeremy at LIPD or Tadd at Elite Diesel. You will have a better performing truck without a doubt!
Old Jan 13, 2007 | 12:33 AM
hosemandc's Avatar
hosemandc
Word out on the street is ......Ditch the Banks chip and get a DP Tuner. http://www.dp-tuner.com/73tuning.htm
Old Jan 13, 2007 | 12:42 AM
bigtorque's Avatar
bigtorque
i second the dp-tuner, you will find there is well over 100 dp tuned powerstrokes on this forum and i havent heard of any problems.
Old Jan 13, 2007 | 06:29 AM
ron's power stroke's Avatar
ron's power stroke
i 3rd the DP great safe costume to your likeing tunes..more hp then the super chip or any other chip..not only does DP tune the motor but he moves the shift points, bumps up the line pressure and locks the tc a little quicker so all the power is all down on the ground...you will never find a better tune..
Old Jan 13, 2007 | 07:06 AM
62trvler's Avatar
62trvler
I4 the DP tuner.................follow the force young Luke
Old Jan 13, 2007 | 07:32 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
DP tuner again. I don't want to sell my old TS chip because i dont want to make anyone run that POS.
Old Jan 13, 2007 | 07:47 AM
Uzumati's Avatar
Uzumati
Yes,,,get the DP-Tuner You must.
Old Jan 13, 2007 | 11:55 AM
zss42002's Avatar
zss42002
the dp it better for my truck and will do all the same things the otto-mind form banks will do?? i dont want to ***** any thing up. i have a manual 6 speed keep in mind and the banks power pack package. i am running boost peak 25 psi. and a steady 20-21psi. will this chip bump that up?? also which one should i order there are several??
Old Jan 13, 2007 | 12:01 PM
ron's power stroke
dp is like putting in a new computer...call jody give him you computer numbors tell him what modds you have now..what you plan to do for mods and what your plans of use for your truck..he will make the tune work better then a banks tune ever will..
