Axle kit
Old Jan 12, 2007 | 12:05 AM
kwizman's Avatar
kwizman
Axle kit
Does anyone know of a good axle bearing or axle kit for a 8.8. I'm looking to upgrade my axles and bearings. I do a good bit of towing with my 92 F150 2WD, nothing excessive, and would like to build a stronger rearend.
Old Jan 12, 2007 | 07:35 PM
kell104's Avatar
kell104
Get good quality bearings and seals. Either CR or Timken. They seem to be the best I have found so far. If you can find a heavy duty version use that.
Use Synthetic gear lube when you are all done, it will run cooler and longer. Milage won't be hurt either.
