76 cluch adjustment
Old Jan 11, 2007 | 09:04 PM
pintoches's Avatar
pintoches
76 cluch adjustment
I have a 76 f250 360 4 speed 4x2 I think my cluch is sliping some. when I press the cluch it releases in about 3/4 of a inch from the top. is there any adjustment left. and which way do i adjust it to make it have more pedal.
The lever on the side of the trany does it need to go forward or back?
Old Jan 12, 2007 | 10:13 PM
Fritolay's Avatar
Fritolay
if your truck uses the z linkage like the 72's do (solid linkage that goes between frame and back of the block) then i would check out the nylon bushings on the link mounts they may be severly worn and replacing them might help you out. if it is not worn out you may want to try and lengthen the link between the pivot and the clutch fork.
