hard starter HELP
Old Jan 10, 2007 | 10:00 PM
boattower's Avatar
boattower
Question hard starter HELP
hello evey one new name old member. my truck wont start unless pluged in or warm from running. average temp 15-20 night 40 day. i have read many posts on subject, few differences every one talks about blowing white smoke mine is bluesh black, clears up after start ???? i have changed fuel lines,O rings,checked starter, battries and did a quick check on gp(6 months old) with test light, can hear gpr clicking. wts light stays on for about 12-15 sec. when i do get it to start i have to pump the pedel. started a while a go getting worse. dont know what else to check any ideas ?? 1990 F-250 4X4 7.3 ,ats turbo, 3" exhaust, std trans
Old Jan 11, 2007 | 12:18 AM
Mr. Bob's Avatar
Mr. Bob
I would take a test light and make sure the GP relay gets power on the other side when the key is turned on...
Old Jan 11, 2007 | 01:48 AM
Agemenon's Avatar
Agemenon
change your gp relay, my truck was acting all retarded until I changed it. I was having starting issues too. Its only 20$ for the relay...cant hurt to try.
Old Jan 11, 2007 | 06:57 PM
Mr. Bob's Avatar
Mr. Bob
I would rather test the component than simply replace it..
Old Jan 12, 2007 | 07:06 AM
F350_Hauler's Avatar
F350_Hauler
Jump the contacts on it for 30-40 seconds and then have someone try to start it. If she fires right up then you need to replace it. If it is still a hard start then I would look for air leak problems(hard start after sitting for a couple of hours hot or cold).
Old Jan 12, 2007 | 08:16 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Try this before doing much else. Clean the ground wire contact on the controler relay. This is the black wire which is attached to a small bolt on the relay. Clean where it contacts on the bolt and where it contacts the intake manifold. On mine I also ran a separate wire from the black wire bolt to the (-) on the battery to be sure to have a great ground. this seems to have solved a lot of starting problems for me.
Old Jan 12, 2007 | 09:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
30 or 40 seconds is a very long time, I would go for more like 10 or 12 seconds before you try to start it.
The ground wire terminal is usually under one of the bolts that mount the relay/controller to the intake manifold.
