Fuel Injector Problem!!!
Old Jan 10, 2007 | 07:36 PM
BB460EFI's Avatar
BB460EFI
I was driving my 88' f350 Crewcab, 460EFI & the S.O.B died on me, and I popped the hood and the front driver side fuel injector located on the top of the motor was leaking fuel and fouled all the plugs-out... Do I have to replace the Injector or can I replace the seals in the injector that is causing it to leak?, I already have a new dist-cap, Rotor and plugs and wires... I was waiting on friday to do a tune-up and now this happens...$80 tow bill... Any knowledge will help...
Old Jan 10, 2007 | 07:44 PM
Conanski's Avatar
Conanski
1 leaky injector fouled all the plugs? How's that possible?
If it was leaking externally, then the O-rings are gone and need to be replaced. If it's stuck open then it would leak inside the cylinder, but you wouldn't see any sign of it externally.
Old Jan 10, 2007 | 08:24 PM
SilverSport's Avatar
SilverSport
1988 .... from the way you described it .... do you have TBI? Throttle Body Injection?
Old Jan 11, 2007 | 05:20 PM
BB460EFI's Avatar
BB460EFI
It fouled 2 plugs !!!
I do believe its thre 0-ring I'm gonna have to get to it as soon as the weather breaks
