glass?
Old Jan 10, 2007 | 06:07 PM
574ford's Avatar
574ford
glass?
does anybody know about how much the left rear sliding window cost?
Old Jan 10, 2007 | 08:16 PM
Dustin1690's Avatar
Dustin1690
Probably not that much maybe go to your local glass shop and get an estimate or even i think (not 100% sure) you could go to a auto wrecker and pick one up out of a truck for cheap I could be wrong
Old Jan 11, 2007 | 12:21 AM
77 Bronco's Avatar
77 Bronco
If your talking about the rear sliding window....the complete window is around $200.00 New...atleast around here. They will probably tell you that you cannot just replace the left side as it is a sealed unit. Good luck.
Sam
Old Jan 11, 2007 | 05:31 AM
Autoglass's Avatar
Autoglass
What year is the truck? Is it a factory installed unit?
DB08178 is the part #, But is it a clear or factory tinted part?
Reason I ask,
DB08178GTY is a clear glass
DB08178YPY is a factory tinted part.
The whole unit will need to be removed from the truck to fix it, Talking @ a 3 hour job at a PPG Autoglass shop! As the posts before me, It is cheaper to buy a new unit! Part # is DY90065 .
Old Jan 11, 2007 | 06:13 AM
574ford's Avatar
574ford
well ****. thanks for the help.
Old Jan 12, 2007 | 05:35 AM
amcjrb's Avatar
amcjrb
glass
Replace the whole back window with a junkyard piece. This is a very simple DIY job, takes maybe an hour for the whole swap (old out, new in). I have done it twice in the last couple of months. I got mine from a parts truck, but at the local pick your own parts yards these cost maybe $20 to $40.
Jim B.
Old Jan 12, 2007 | 09:37 AM
lostin90s's Avatar
lostin90s
Easy job just takes time . Get a 94 up window latches are better.
Old Jan 12, 2007 | 12:28 PM
95Ford4x4's Avatar
95Ford4x4
i paid $130 for the dark tint glass and 30 for new rubber seal on my 95 from JC Whitney. you don't mention the year of your truck, but it is worth the money to buy a new seal, just lay it out in the sun for awhile before installing to get it good and plyable.
Old Jan 12, 2007 | 05:15 PM
574ford's Avatar
574ford
wow. i had a guy come put the whole brand window in at my house for 180$ and he had to drive 35 miles just to come to my house. dark tint window and installed 180 dollars not to bad.
