How long does a 5.0 engine last?
Old Jan 10, 2007 | 05:25 PM
nitrochevy's Avatar
nitrochevy
First timer here!! I'm looking at a '94 E-150 van on eBay and it has 140k miles on it. I'm wondering how much life this motor still has in it??
Also, any thoughts on the transmission?? I believe it's an AODE.
thanks,
Elvin
Old Jan 10, 2007 | 05:33 PM
HemiEater's Avatar
HemiEater
I say it will run for 141,000.00 mile and then stall at a stop light and never run again, the transmission will be sold to a little old lady for 300.00 and will last another 25,000.00 miles.
....LOL
Old Jan 10, 2007 | 05:37 PM
nitrochevy's Avatar
nitrochevy
Thanks, maybe I should stick with chevies....lol
Old Jan 10, 2007 | 05:40 PM
HemiEater's Avatar
HemiEater
good one............Glad you have a sense of humor.........
Back to your ? I've seen them go over 200,000 but as you know it all depends how it was mantained....and driven
Old Jan 11, 2007 | 06:09 AM
d79f150's Avatar
d79f150
250K on my original 5.0 in my 93 f-150 the e4od however has seen better days
Old Jan 11, 2007 | 08:07 AM
paden's Avatar
paden
I agree that 200,000 is possible. If it has been used hard then you would get a lot less of course.
In the mid eighties engines if you tow large loads with it often they seem to be prone to breaking the crankshaft. In other words they aren't really meant to tow large loads but that shouldn't be too much of an issue in a van. They may have overcome the breaking cranks too between the mid eighties and ninetys.
The block is usually still good after the crank breaks though. I had one engine that broke two over 300,000 miles and two rebuilds. I towed a 24 foot gooseneck all over the US with it too though so those were 300,000 very hard miles. I have seen one other break on a different pickup also.
Old Jan 12, 2007 | 08:50 PM
theonlybull's Avatar
theonlybull
i had one run 340,000 km's that was out of a crown vic.... depends on it's prior life, some last good, some don't
Old Jan 12, 2007 | 09:11 PM
jade79's Avatar
jade79
79 302 - 250,000 miles
95 5.0 - 180,000 miles
Both still run smooth and strong and burn little or no oil.
Old Jan 13, 2007 | 05:22 AM
s1120's Avatar
s1120
Once you get over 100K it depends on the care the motor receved. If it was taken care of 200K is no problem. I have seen many.
Old Jan 13, 2007 | 08:50 AM
awe1979's Avatar
awe1979
1991 F150 285,000 still running strong. AOD was rebuilt at 225,000.
Old Jan 13, 2007 | 08:57 AM
AMDCAMARO's Avatar
AMDCAMARO
My experience has been around 140k. Now lil old ladies who drive crown vics may get 300k.
The 92 i just bought went at 140k. Still ran but had low comp and leaked oil back out the intake into the airbox. (bought it knowing it had a bad motor for $400.00)
My 86 fulie lost all oil pressure at idle at 130k but would make decent pressure when driving down the road , and had a valve stick at 145k. and broke the timing chain.
Old Jan 15, 2007 | 04:28 PM
P51D Mustang's Avatar
P51D Mustang
We have a GT40 spec 5.0 pushing 140K. It has great oil pressure, doesn't burn any oil, and still gets about 285 HP at the rear wheels. Should we do a pre-emptive tear down?
Old Jan 16, 2007 | 09:09 AM
cjg1999's Avatar
cjg1999
thanks,
Elvin
I have a 94 F150 I just bought with 181,000 miles, the motor is very strong with great oil pressure. I would say they will last well over 200,000 miles if maintianed.
Old Jan 16, 2007 | 10:07 AM
d79f150's Avatar
d79f150
If it ain't broke ... don't fix it.
Old Jan 16, 2007 | 02:40 PM
fatboyf150's Avatar
fatboyf150
i just turned out 253,000 hard miles out of my 94 351w. when we flipped it over on the engine stand, removed the rod ends, 2 pistons fell out on there own. it was slap wore out. ran great but had so much blow-by. it would blow the dipstick out the engine.
