Sponsored by: Real Truck
Brake noise
Old Jan 9, 2007 | 10:48 PM
Bracen's Avatar
Bracen
Brake noise
Okay, I've had my truck for a little over a yeear now. 02 F-350 v10 4x4. It's got a little ove 60k on it. I noticed almost from day one there was a brake squeal, well it's more like a groan from the left front. Only under moderate pressure, the kind you use in everyday driving! So I ripped my brakes apart thinking that they could just use a quick service. I cleaned the pad, calipers, hardware, hell I even machined the rotors! Put it all back together and the noise came back on the way home. So I waited a couple months (Because my pads still had 50%+ on them) then I ordered some new ford pads and did the front brakes, I took extra care to machine the rotors (We have a ammco lathe and i put new bits in it!) and cleaned everything up. Even flushed the brake fluid. Sure enough on the way home the same damn noise!!! I've lived with it for a while but now it's driving me nuts! Anyone have any ideas?
Old Jan 10, 2007 | 08:02 AM
redford's Avatar
redford
FTE Leadership Emeritus
I'd try a different brand of pad.
Old Jan 10, 2007 | 12:04 PM
rmilchman's Avatar
rmilchman
I have hawk pads and my front left is doing the same thing. I'm beginning to think it's time to replace the brake hose.
Old Jan 14, 2007 | 10:33 PM
nickf2504x4's Avatar
nickf2504x4
try thermo quite and also check your cailiber sliding pins and make sure to clean and lube them with dyelectric grease
