GlowPlugs for a remote starter
For the 06 I am told there is a sensor remotes can tap into but it is a computer signal of some type, and the module is a few hundred bucks. Since the 10sec delay has been working fine for me, I never made the added investment.
I do use the block heater for nights below 0 F when possible. Sometime's the truck is left at a construction site with no power and the option is not available.
Shorten your delay time.
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 2003-2004 / Remote Start
12volts yellow & lt. green/purple + ignition harness
Starter green + ignition harness
Second Starter N/A
Ignition red/lt. green or white/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray/yellow & red/black + ignition harness
Second Accessory blue/lt. green + ignition harness
Keysense
Power Lock see notes
Notes: Without keyless entry use pink/yellow for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use white/red for lock and black/white for unlock. They are negative trigger and found at the VSM.
On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Power Unlock see power lock notes
Lock Motor pink/black 5wi VSM
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor red/orange 5wi VSM
Parking Lights+ brown + headlight switch
Parking Lights- N/A
Hazards same as turn signals
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + steering column
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + steering column
Reverse Light black/pink + fuse box
Door Trigger black/lt. blue + passenger kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer NOT red/lt. green ac any ignition coil
Notes: On diesel vehicles the tach wire is green/white in a 5 wire harness held up with white tape behind the parking brake release.
Wait to start see DirectFax document 1091
Brake Wire lt. green + brake pedal switch
Parking Brake lt. green/red - parking brake switch
Horn Trigger blue - steering column or VSM
Memory Seat 1 brown/lt. green - memory mod under dr seat
Memory Seat 2 black/orange - memory mod under dr seat
Memory Seat 3 N/A -
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
