'77 Column Shifter Locked Up
Old Jan 9, 2007 | 11:37 AM
slstreit's Avatar
slstreit
Question '77 Column Shifter Locked Up
Hi Folks. New around here.
Have a '77 Highboy and cannot move the shifter for the Automatic. (it barely goes into reverse but no further and is clearly in a bind) Disconnected from the transmission to confirm where the problem is.
Anybody know what usually happens in the column on these and what most probably needs to happen to repair it?
Thanks in advance for any help!
Old Jan 9, 2007 | 11:43 AM
73f350sc's Avatar
73f350sc
Usually it means that the collar that the shifter is attached to has broken off the shift tube on the inside of the column....youll have to take the steering wheel and turn signal cam off to see if it is. Mine had the same problem one day so I tore it apart..the thing was only barely attached.
-Chris
Old Jan 9, 2007 | 12:48 PM
arctic y block's Avatar
arctic y block
The coller is avalible at most parts stors as it is a comon problem.
Old Jan 9, 2007 | 03:26 PM
Mil1ion's Avatar
Mil1ion
The bottom arm of the column that the linkage rod is connected to can round out as well ..then bind
See the column related threads on this or page 2 for a picture of it.
Old Jan 9, 2007 | 04:25 PM
arctic y block
Seems like every time I post. I remember (oh ya) there is this It could be also. And There you are Dennis. Right on every time. This is a good thing. Thanks. Bushings on both ends can be bad. Or a stick or frozen mud and snow at tranny linkage as well.
Tricky
Old Jan 9, 2007 | 10:00 PM
75shortS/C's Avatar
75shortS/C
Column shifter repairs
I'm currently trying to repair my own column shifter and have found that the collar broke off around the tube. The collar was easy to get a my local ford dealer, as was the turn signal switch, but I had to get the canceling ring from LMC as well as the bearing and turn signal holding (steering column tube flange) which was damaged because a screw came out of it. The only part that I haven't been able to find is the transmission selector lever(D3TZ-7210-C), which I may have to repair by welding it up and the grinding it to fit the selector detents, unless any one has a source for new ones.
Old Jan 11, 2007 | 12:31 PM
slstreit's Avatar
slstreit
Thanks Gentlemen.
What broke was the detent piece on the backside of the selector housing. It broke off and wedged itself. Problem is that it's obsolete. The shift collar is in excellent shape. Any suggestions of an outfit that reproduces these?
Part #D4TA-3511-DWA.
Thanks
Old Jan 11, 2007 | 01:08 PM
Mil1ion's Avatar
Mil1ion
I don't see the part you mention here
Do you not live near a wrecking yard to get one from another truck ?
Old Jan 11, 2007 | 02:29 PM
slstreit's Avatar
slstreit
Looks like it's actually called the "upper flange". It houses the turn signal switch and the bearing.
I did actually find it thanks to this forum. The reply #6 mentioned an outfit called "LMC". Wow. That outfit's got it all.
Thanks alot folks. Much appreciated.
Old Jan 11, 2007 | 04:15 PM
73f350sc's Avatar
73f350sc
Uh oh...you said the magic word ..........lol........right Dennis?
-Chris
Old Jan 11, 2007 | 04:30 PM
Mil1ion's Avatar
Mil1ion
Yes they have lots of stuff but LMC is NOT an FTE sponsor.
and they aren't the only ones with this part
Please Patronize FTE sponsors they keep this web site online.
Get it at BOTP or Mac's instead
http://blueovaltruckparts.com/catalo...ducts_id=11150
Old Jan 11, 2007 | 07:25 PM
75shortS/C's Avatar
75shortS/C
Question 77 Column Shifter Locked Up
Does anyone know where to get a replacement shifter lever(d3tz-7210-c)
Old Jan 11, 2007 | 07:49 PM
Mil1ion's Avatar
Mil1ion
Click the link on my post above
Old Jan 12, 2007 | 01:48 PM
slstreit's Avatar
slstreit
OOPS!
10-4
Didn't know.
Old Jan 15, 2007 | 08:55 PM
75shortS/C's Avatar
75shortS/C
Shifter Lever(D3tz-7210-c)
It appears that this part is not available from BOTP, LMC, Dennis Carpenter, or Auto Krafters, or my local dealer, so I guess that I go find someone with a tig welder to repair it. It looks like this would be a good part for someone to invest in reproducing.
