Sponsored by: Auxito
Question
Old Jan 8, 2007 | 11:12 PM
Lance1601's Avatar
Lance1601
Question
Hello. I have a '99 F150 4x4 SuperCab that has an ABS light come on occasionally. Nothing in particualar seems to trigger it. I went Advance Auto and Autozone to see if they would check the codes for me and they both said they're scanners don't check for ABS lights, only check engine lights. I was wondering what the problem is and if it should be corrected ASAP. Thanks.
Old Jan 8, 2007 | 11:36 PM
Octane's Avatar
Octane
You need an ABS scanner, an OBD-II scanner wont check for codes in the ABS system. Most likely you have a sensor that is bad. My '99 F-150 does the same thing.
