Dually question
Old Jan 8, 2007 | 10:34 PM
Chistoso's Avatar
Chistoso
Question Dually question
I bought a early 99 F350 DRW 4x4. 188,000 miles all stock. To be used on weekends, pulling the boat with cab-over camper, Etc. I just noticed it has no spare tire. Where is the best place to buy a spare. Does one spare rim fit on all 6 wheels?
By the way, I've been lurking for a few weeks and have changed all the fluids, bought a CPS to keep in the glove box and did the fuel drain O-ring repair. Thank you to all who posted info with pics.
Patrick.
I have a few of the Viton O-ring seals left over if anyone needs them.
Old Jan 8, 2007 | 10:45 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Your local junk yard should have a stock steel wheel spare (not chrome). Yes, the spare will work on the front or rear.
Old Jan 8, 2007 | 10:50 PM
clintbonnie's Avatar
clintbonnie
Welcome to the forum. If you had a spare, it would fit all six positions. You would just reverse the wheel for the inside duals. Try a wrecking yard or any tire dealer for a tire and a wheel.
Old Jan 9, 2007 | 07:45 AM
GoBigOrange's Avatar
GoBigOrange
Patrick,
You might also try a used tire/wheel dealer of even E-bay (be sure the shipping doesn't kill you). The others are right about the wheels all being the same. There are a lot of these trucks around and I'm almost positive that the other manufacturers use the same bolt pattern- just check the width and be sure you get the same diameter as you have now. 16.5" and 16" are not the same. Also, DO NOT get a two piece rim- they are dangerous and many tire shops won't even work on them any more.
John
'03 F350 CC, DRW, K&N intake, Superchip tuner, 2.5" cat back duals, 91 gallon transfer tank/toolbox combo. Pulling 44' LQ horse trailer.
