fuel filter help
Old Jan 8, 2007 | 08:26 PM
68bluebeast's Avatar
68bluebeast
fuel filter help
Can some one tell me where the fuel filter is located on a 1968 ford f-250 with a 390 if it is the kind that is inside the fuel pump how do you get it out? also I have a new holley carb and I can not seem to find the filter on it, any one know where it would be on the carb.
Old Jan 8, 2007 | 09:02 PM
Fritolay's Avatar
Fritolay
the filter on your pump should be right under the pump in a canister and to get to it just get a good grip an unscrew it.
Old Jan 9, 2007 | 09:06 AM
TigerDan's Avatar
TigerDan
Depending on the model of Holly, the one on the carb should be right under the large fitting on the float bowl that the fuel line screws into. Remove the fuel line, then remove that fitting and it'll come right out. It's a cleanable filter.
