lower boost
Old Jan 8, 2007 | 07:48 PM
somy43's Avatar
somy43
lower boost
When performance module was installed the boost dropped from 29 to 25. But the perormance was very noticeable, 3.5 seconds faster 0 to 80. Is there any thing about the drop in turbo boost that is negative ,or is this ok. The truck tows better also.
Old Jan 9, 2007 | 06:00 AM
BowTieHatr's Avatar
BowTieHatr
where ar you getting those numbers? what module did you put on?
Old Jan 9, 2007 | 07:14 AM
somy43's Avatar
somy43
The boost gauge, Granatelli mileage miser.
Old Jan 9, 2007 | 08:10 AM
BowTieHatr's Avatar
BowTieHatr
you mean the one built into the cluster?
Old Jan 9, 2007 | 08:39 AM
npccpartsman's Avatar
npccpartsman
One thing you have to remember.....high boost is NOT necessarily a good thing. I'm not saying 29 is high by any means, but just because it doesn't boost like it used to doesn't mean there's anything wrong. Have you returned it to stock to see if it went back to 29? If so it may just be in the programming of your module. It's a mileage MISER right? which means you should expect a loss of performance maybe???? NOT.
