how much can you tow with F-450
Originally Posted by DFord79
Your F-450 with 4.88 gears is designed with a 33,000# GCVW. towing 25,000#s puts it at or just about the legal limit. However the truck will do the job.
'00 F-450 Regular Cab with 6 speed
Vehicle Curb Weight - 6500# - 7000# depending on wheel base. Plus options, i.e. 14' Bed.
GVWR - 15,000#'s
GCWR with 4.88's - 26,000#s
MAX 5th wheel weight - 18,200#'s
Originally Posted by 220KF250
What size Hitachi is that? I've got a tandem axle trailer that I pull behind my '05 F250. I've had 5 ton on it and the trailer weighs 3K ----- and it still surprises a bunch of HOKIE-POKIES at the stop lights. The trailer TOW/COMMAND package is GREAT!! ..... even though I have surge brakes on the trailer ('cause I tow with several other trucks, too).
might i suggest a exhaust brake to help you slow it down.i've been running equipment ,and hauling equipment for over twenty five years,and i'll tell ya you will be ok in the beginning,just like the guy with the pic of his truck w/tiny hitachi.but his ANDyour day will come when it just wont stop,and just pray to god that what you hit isnt a BIG YELLOW 50 passenger international!!! if you know what i mean
I cant beleive your doing that on a srw truck with a hitch rated for 12k with a weight dist setup....that dozer and trailer has to weigh at least 26k
To the guy about the cdl....thats a common misunderstanding.....
you have to have a cdl to tow 10k if the GCWR is over 26000 lbs....like this setup above....
in other words, if your truck was 7k and you were pulling 18k you wouldnt need a cdl because your gcwr is less than 26001
if your truck is 7k and you are pulling 20k you need a cdl because your gcwr is over 26001
#28
#29
Originally Posted by jake00
actually, the trailer limit for needing a cdl is 10000lbs, its 26k for a straight truck
Yes and he said he is towing 25,000 lbs. If you remember from 2nd grade 25,000 is more then 10,000. Also he not only exceeds that parameter he also exceeds the parameter that says you need a CDL if the GCWR of the vehicle and anything its towing is over 26k lbs. So he meets both parameters and thus definitely needs a CDL.
#30
