Sponsored by: Auxito
97 f150
Old Jan 8, 2007 | 05:20 PM
jwg1960's Avatar
jwg1960
97 f150
New guy with a 97 F150, 4.6, K&N air filter, 265,000 miles. I had a few problems this past week, most of which I think are cleared up now. I do have a couple more bugs to work out. Seems to be running fine.
1. Check Engine light is on. Codes EGR. What is the best course of action to solve this? I was told this could be one of several things. Don't want to spend a ton changing out sensors.
2. Backup lights don't work. They haven't for some time. (New Bulbs). They would work sometime if I moved the shift lever half way between Park and Reverse. Took it Ford dealer and was told the switch on the Trans. was good and set properly. After I left, they don't work at all. Is there another switch besides the one on transmission?
Thanks,
Gotta get a half million out of it.
Old Jan 9, 2007 | 03:19 AM
LxMan1's Avatar
LxMan1
Welcome to the forum
1) If the ports aren't clogged, then it's possibly the DPFE sensor. (EGR sensor)
2) The only switch that I know of is the one on the tranny.
Old Jan 9, 2007 | 06:31 PM
slsharratt's Avatar
slsharratt
I have the EGR thingy going on too, Autozone guy said the EGR valve part is about $45.
Old Jan 10, 2007 | 06:26 AM
Joe Finn's Avatar
Joe Finn
Slsharratt, you don't say what engine or year your truck is, but I suspect you are talking about a P0401 code. Do a search for that code and you'll see that it is very unlikely that the EGR valve is the problem.
Old Jan 11, 2007 | 06:33 PM
jwg1960's Avatar
jwg1960
Thanks for the info. I'll probably change the switch this weekend.
nightowl263
Feb 26, 2016 12:51 PM
tonyjklh
Mar 8, 2014 11:02 PM
tcoates
Mar 9, 2009 03:41 PM
grappledad
Electrical Systems/Wiring
Apr 10, 2004 11:49 AM
Brandon_J
Jul 11, 2001 11:52 AM
