another mirror removal question
Old Jan 8, 2007 | 02:43 PM
Downriver Thunder's Avatar
Downriver Thunder
Simple one, millions of search results and no time to rummage through them. I have to replace the tow mirror on my X, it's rather easy isn't it?
Old Jan 8, 2007 | 02:51 PM
WJC's Avatar
WJC
Yes It Is, Just Remove The Interior Door Panel So You Can Get To The Wire Assembly (power Mirrors) And Remove The Small Plastic Piece At The Top Of The Door Which Covers The Bolts That Hold The Mirror In Place. Takes No Time At All, Just Do Not Over Torque The Bolts, Had One Snap On Me.
Old Jan 8, 2007 | 02:56 PM
Downriver Thunder
Great, thanks! Now if I can just talk my boss into replacing my driver's seat skins and heater life would be grand!
Old Jan 8, 2007 | 04:51 PM
WJC's Avatar
WJC
Talking
Thats A Little More Difficult, Had To Replace The Drivers Side Seat Leather On My Old Excursion, Took About Two Hours Because You Have To Take The Seat Completely Apart, But After A Few F&$# You Fights With My Wife, Whom Was Trying Her Best To Assist, We Got The Job Done. Ordered My Parts From Fordparts.com, They Have Oem Ford Replacement Covers For Low Cost.
Old Jan 8, 2007 | 05:47 PM
afreemanmd's Avatar
afreemanmd
Back to the mirror question. The electrical connection is behind the speaker, so that has to come off too after you take off the door panel.
btw, the mirrors have 4 bolts (two are hiding under the rubber plugs, and the other behind the little black panel underneath the sticky foam sheet thing.
Hope that helps!
Isaac
Old Jan 8, 2007 | 08:52 PM
aklim's Avatar
aklim
Well those are 5.5mm metric bolts. Also mine had a single round plug so it was easier when replacing it.
Old Jan 9, 2007 | 07:48 AM
vettdvr's Avatar
vettdvr
Did you replace just one piece of leather? If so,, what was the cost. I have some seat damage and the estimate to repair is $300, but depending on cost for new leather I might do the work myself.
Thanks Jim
Old Jan 9, 2007 | 09:12 AM
WJC's Avatar
WJC
Go To: Geniun Ford Parts You Can Search All Parts, Interior And Exterior At Discount Prices. All Parts Are Oem. The Leather Seat Cover For The Limited Is Listed At $201.76, Remember, This Is Just The Leather Seating Surface, Does Not Include The Seat Back Surface, That Is A Seperate Purchase.
Old Jan 9, 2007 | 02:00 PM
Downriver Thunder
Can anyone give me some tips on how the passenger door panel comes off?
Old Jan 9, 2007 | 03:26 PM
vettdvr's Avatar
vettdvr
Check the tech files for door actuator. There are detail photos showing how to remove the panel. Same procedure to work on the windor or actuator. Jim
Old Jan 9, 2007 | 03:30 PM
Downriver Thunder
Thank you very much vett, I didn't even realize that folder was there.
Old Jan 9, 2007 | 03:48 PM
WJC's Avatar
WJC
Just Pull Up On The Door From The Bottom Of The Panel And The Arm Rest, It Will Slide Out Of The Groves On The Door. Its A Little Bit Of A Pain In The A&* To Put Back In Place Because You Have To Make Sure All The Groves Line Up With The Door.
Old Jan 9, 2007 | 04:27 PM
vettdvr's Avatar
vettdvr
You're welcome,, I didn't know it was there either until someone told me. Jim
Old Jan 11, 2007 | 09:35 AM
Downriver Thunder
New mirror is on, thanks for the advise guys. The only thing I don't like is the driver's side mirror is the original style, the new passenger is the break forward and rear style so there is a bit of difference but I don't think you'd notice it unless you're looking for it.
