Sponsored by: Real Truck
Steering: undriveable
Old Jan 8, 2007 | 01:13 PM
dentistky's Avatar
dentistky
I have a 7/98 F250 SD 4x4 5.4L triton. I parked it and when I came back couldn't move the steering wheel without putting my back out.(there was no reduction in power steering prior to this). The wheels turn under force but I'm not going to attempt to drive it. I suspected the power steering: belt ok, ps pump going round, no squeaks or noises, ps fluid ok. So I checked the brakes, again fluid ok but pedal pushes nearly to the floor. I searched the forums and there seems to be many similar problems although they do not appear to be as severe. I have read that the hydroboost is shared by both systems so will ask my mechanic to look, bleed the system.
Any other ideas would be appreciated.
Cheers
Richard
Old Jan 8, 2007 | 01:15 PM
redford's Avatar
redford
FTE Leadership Emeritus
Thumbs down
Welcome to FTE!
I thought only PSD trucks had hydroboost.
I think you have 2 separate problems. First, you probably need a new master cylinder.
Second, you need a new power steering pump.
FreeDevin
Jan 13, 2014 09:28 AM
Enomra
Jul 10, 2012 01:08 PM
deluxe fab
May 28, 2012 02:20 PM
SSSimon
Sep 29, 2010 04:51 AM
TiggerF250
Dec 29, 2004 12:50 PM
