aod leak
Old Jan 8, 2007 | 11:31 AM
b69bama69's Avatar
b69bama69
Question aod leak
i have 86 bronco 302efi aod tranny, i have a leak coming from the front of the tranny where it bolts up to the motor. i replace the front seal but still no change. what else could it be coming from?
Old Jan 9, 2007 | 05:52 AM
stuart1's Avatar
stuart1
The bushing in the pump could have pulled forward and is cutting off the return hole.
There is also a gasket and "O" ring that should be replaced.
I have seen hubs crack around the weld.
Old Jan 9, 2007 | 12:37 PM
mudgepondexpress's Avatar
mudgepondexpress
Sometimes the torque converter cracks under pressure. Mine poured fluid out when running, but nothing while stopped.
Kenny
Old Jan 9, 2007 | 03:01 PM
b69bama69's Avatar
b69bama69
mine is only leaking when its not running i believe. i call a tranny shop today and they would replace all the outer seals for $160 if i pulled the tranny. does that sound about right on the price?
