Sponsored by: Real Truck
Tail Light Wire Confusion??
Old Jan 8, 2007 | 11:22 AM
JDS549's Avatar
JDS549
Question Tail Light Wire Confusion??
1999 F250--The rear was wiped out in a wreck and after building a steel flat bed I cannot find a diagram for the wireing to the tail lights. I got the backup and trailer ok and even liscense light. Each side has 3 wires, ground,tail, stop & turn.Can anyone tell be the color code for these lights. as always, my many thanks. Jds 549
Old Jan 8, 2007 | 04:47 PM
chuck06250's Avatar
chuck06250
Try here-
https://www.fleet.ford.com/truckbbas/
Old Jan 8, 2007 | 07:55 PM
sgthawkusmc's Avatar
sgthawkusmc
Or just use a multi meter. Turn your blinker on and see which one is going from 12vdc to 0vdc or so and so on.
Old Jan 8, 2007 | 08:01 PM
JDS549's Avatar
JDS549
Smile
tried the multimeter thing and found tail to ground, went to that to find ground wire, and when hooked up I found the light will work from one power to an unused power. tks, jds
Old Jan 8, 2007 | 09:30 PM
ReAX's Avatar
ReAX
I use hoppy's info all of the time. http://www.trailerwiring.com/inst/48485.pdf this is one for a 7 wire, but the color code is somewhat standardized.
Old Jan 8, 2007 | 09:48 PM
JDS549's Avatar
JDS549
Smile Jackpot
I think what you are telling me to do is trace the wires from the trailer plug to the tail lights for the correct wire. I had not though of that but it might work because the trailer plug was not compromesed. I'll try it. MANY THANKS
