Flathead gasket leaks
Old 01-12-2007, 08:50 PM
'50 PHATTY's Avatar
'50 PHATTY
'50 PHATTY is offline
Ross, thanks for the reply. I didn't see it before my last post. Anyway, I did get some thread sealer and am cleaning everything up tonight. I will definitely take heed to all of the advice. NAPA didn't have the gaskets locally either, but I did check.
thanks,
Kevin
Old 01-12-2007, 11:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Get some hardened SAE washers for your head bolts, that will give you about an eighth of an inch more thread. As I recall, the ones for 302's are about right, but just go to NAPA and match some up to your bolts.
You might even ask them if they sell a head bolt set, as I recall they are still available. Grade 8 are good bolts but there's more to the correct bolts than strength. Depending where you bought your Gr 8's, they could be pretty crummy bolts these days -- lots of asian junk around.
Old 01-12-2007, 11:29 PM
'50 PHATTY's Avatar
'50 PHATTY
Originally Posted by ALBUQ F-1
Get some hardened SAE washers for your head bolts...you might even ask them if they sell a head bolt set
Thanks for the advice about the washers, seems so obvious, duh. A lot better than buying new bolts. The problem isn't with the thread, I actually have more thread than the originals. I think the problem is that the bolts are a little too long. Hopefully that washer will do the trick. As far as the bolts, I had a lot of trouble finding them. It seems everyone, including NAPA, is out. Some say they have been backordered since Aug/Sept. Something to do with incorrect threads on the last big batch or something along those lines. There is another thread that just started tonight by someone having the same problem.
Kevin
Old 01-13-2007, 07:56 AM
Christopher2's Avatar
Christopher2
Christopher2 is offline
Duplicate post
Old 01-13-2007, 07:57 AM
Christopher2
The manual does say to use a water resistant sealer to prevent leaks around the head bolts.
Old 01-13-2007, 06:01 PM
F6Guy's Avatar
F6Guy
F6Guy is offline
I would think that the bolts will be strong enough as the originals were only grade 5. The main issue would be if they are shouldered or not.
BdgrDuckHntr
27
11-07-2018 12:36 PM
maxum96
10-28-2016 08:15 PM
kr98664
15
09-27-2016 01:21 PM
genscripter
19
05-10-2015 03:57 PM
mark1986F150
03-13-2015 08:52 PM
Quick Reply: Flathead gasket leaks
