Headlight switch - headlights parking lights question.
I just finished wiring up my headlights, front parking lights, dash, etc. I believe everything is working as designed.
Question regarding the headlight switch -
Switch all the way in = no lights
Switch pulled out in the middle postion = parking lights but no headlights
Switch pulled all the way out = no parking lights but headlights.
I think this is correct but i just wanted to make sure. Additionally, I think i would like my parking lights (in front) on when my headlights are on (if the above scenario is correct. I was just wondering if others have done this (wanted the parking lights on with the headlights). If so do you just disconnect your parking lights from there terminal on the head light switch and connect them to the headight terminal. Then my headlight switch would only work when it is pulled all the way out (but both the headlights and parking lights would be on at the same time.
Is this correct??? Or have others accomplished this a differant way?
Thanks in advance
Rich
51 ford f-2 flathead v-8
that is the stock way it works
you could hook up the running lights to the DASH/TAILLight side of
the switch that is on in both location of the headlight switch
hope this helps
Joe
