More engine swap troubles
Old Oct 21, 2000 | 03:06 PM
jearly's Avatar
jearly
Once again I'm having troubles with my engine swap. The engine cranks but it won't turn over. There is spark coming out the spark plugs. I'm not sure about the timing though. The timing mark is not on the engine anymore so I don't know what to set it to. If anyone knows how to set the timing without the mark I would really appreciate it. Also I took a compression test on all the cylinders (the tester wasn't the best so I don't really trust these numbers) and they range from 10.0, 9.0, 9.0, 8.0, 6.0, 6.0, 4.5, and 3.0 . I'm not sure if that could be a factor to keep it from turning over or not. Again this is a 302 from a 79 F-150. Thank you so much.
Jim
Old Oct 21, 2000 | 08:14 PM
jearly's Avatar
jearly
Nevermind, turns out the engine wasn't cranking fast enough to suck the gas down the line so it wasn't getting gas to the carbuerator
Old Oct 23, 2000 | 09:41 AM
copeina's Avatar
copeina
macubus
2004 - 2008 F150
Aug 3, 2019 01:03 PM
Aidanw
40
Jan 14, 2017 12:04 PM
countrydriven
Dec 23, 2016 02:39 PM
Jasonf150
15
Apr 16, 2016 07:02 PM
TheBlahMasta
1997 - 2003 F150
Sep 23, 2015 06:20 PM
