okay i new to this forum but i have a 64 f250 4x4 that i want to put a brownie box in between the transfer case and main tranny for more gears so i can cruise at 55 comvertably. i have never seen a brownie so i need to know what models would have small enough dimensions to fit. i want either a direct/overdrive or a three speed. i also need to know what one of these would be under so i could go back road scroungeing. and help would be appreciated.
well i have already been to the gmc site as well as gear vendors and i have search brownie on this site and found quite a bit but not acutual demensions and factory applications
I've done some research also and come up with about the same thing. The GMC site does list them as being 18 13/23" ( assume it's supposed to be 13/32") long which is pretty HUGE. I'm on the hunt for one, if I find one for a decent price, I'll post some dimensions.
this is really off the wall but would a dana 24 transfer case stand up to running backwards. i know this would put the pressure on the wrong side of the gears plus how much noise would it make. if this would work you could run a driveline in the out put and get a significant overdrive.
