voltage reducer
Old Nov 3, 2006 | 06:27 PM
doug51f1's Avatar
doug51f1
I reversed it just to see what happens, I would not reccomend it. It seems to shorten the life span of the IR to about 3 seconds.......hahahaha. I don't know if reversing it really did it in or not, but it no longer has any output voltage. The one I have is pretty clearly marked IGN on one terminal. I assume that would go to the ignition switch.
I tried removing the jumper bar that runs from one gauge to the other on the hot side in my cluster and hooking them up individually and also tried reversing the connections on the gauges, except the gas gauge since it was working correctly.
No dice on any of those combinations, especially now that the regulator is dead.
I have seen all of the gauges move through their entire range, so I know that they are responding to something.
Could it have anything to do with the sending units? I'm running a late 60's 289 with appropriate sending units for that motor. Is it possible they just plain aren't compatable with the gagues?
Old Nov 3, 2006 | 06:40 PM
SteV8e's Avatar
SteV8e
Check for continuity (0 Ohms) between the sender and the gauge. To test the gauges, disconnect the leads from the terminals and apply 1.5 Volts DC across them. The gauge needle should rise to the center of the range and hold. That tick mark at the base of the gauge face marks the center. The needle should be close to center; if not, replace the gauge.
Old Nov 3, 2006 | 06:56 PM
doug51f1's Avatar
doug51f1
Continuity is no problem, I just ran new wires with the new senders. I'll check the gauges in the morning. Thanks for the info.
doug
Old Nov 3, 2006 | 09:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The problem is almost certainly the senders not being compatible. The old flathead era temp senders were bimetal, pulsing type, while newer stuff is more like a variable resistor. If you use the old senders with the new engine you should get correct readings. You may need to use a trimming resistor to get them to read correctly.
My IR was reversed for a month and didn't smoke off; makes me think your new senders have a real low resistance or something.
Old Nov 3, 2006 | 09:21 PM
doug51f1's Avatar
doug51f1
This all makes me a little sad. The original senders are long gone and before my time with the truck. The engine swap happened about 20 years ago and then the truck sat in a barn for about 15 years and waited patiently for me to find it and bring it back to life.
Maybe I should have left well enough alone and stuck with the vintage SW gauges that used to hang under my dash.....
Old Nov 3, 2006 | 11:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Send me an email, I believe I have a flathead sender you can have. I suspect it may be a little long for the 289, may need an adapter.
Old Mar 1, 2011 | 08:00 PM
daveaprile's Avatar
daveaprile
Wire placement on IR1
Can you tell me which side is input and which is output
AtlantaBoy
Mar 19, 2015 06:22 PM
ascheperle
Aug 7, 2013 06:09 PM
ungerp
Oct 23, 2011 05:07 PM
mattsautobody442
2004 - 2008 F150
Sep 21, 2009 02:35 PM
oldjag
22
Feb 3, 2007 05:54 PM
