Sponsored by: Auxito
High Idle all the time
Old Jan 6, 2007 | 09:55 PM
mrsteveo19761982's Avatar
mrsteveo19761982
I have a 5 speed, 4.6 liter f150. When I drive it, it stays at what I was driving at like 2000 rpm. When I come to a stop it eventually comes down to almost normal. I have replaced both the IAC and the TPS. My next step is to replace the connectors any better ideas? Need ideas thanks.
Old Jan 6, 2007 | 10:36 PM
Bluegrass 7's Avatar
Bluegrass 7
Do a check of the cruise control that might be causing the hang up of the throttle.
This is a bad situation in event of a panic stop, having the motor driving that hard with little reaction time.
Find the problem or don't run the truck until it's solved for safety..
Old Jan 6, 2007 | 10:51 PM
Ultramagdan's Avatar
Ultramagdan
If you have to drive it, when braking, take it out of drive. It will stop a whole lot easier.
Old Jan 7, 2007 | 10:41 AM
mrsteveo19761982
Any other ideas, the truck is a manual and no cruise?
Old Jan 7, 2007 | 02:11 PM
Wilber15's Avatar
Wilber15
Check for vacuum leaks....Unmetered air entering the Intake causes high idles.
