Gearing question
Old Jan 6, 2007 | 09:12 PM
cradar69's Avatar
cradar69
Question Gearing question
I have lifted my truck and now need to buy the right ring and pinion. Does anyone know any websites that give this calculation?
Old Jan 6, 2007 | 09:23 PM
Conanski's Avatar
Conanski
You don't need to change gearing with a lift, but if you fitted larger tires then gearing would certainly help.
Old Jan 6, 2007 | 09:32 PM
cradar69's Avatar
cradar69
I have a 1996 F-150 ext cab long bed 4x4 with 6" suspension lift and 35" tires. It has 3.55 gears and now I am obviously having problems with the overdrive and highway speeds. I need some direction as far as 4.10 or 4.56.
Old Jan 6, 2007 | 09:49 PM
Conanski's Avatar
Conanski
Yep. Try this one...http://www.csgnetwork.com/multirpmcalc.html
Plug in your factory tire size, which was 28", 3.55 gears and pick 60mph for example. Now look at the engine speed for AOD. Next change the tire size to 35" and you'll see the engine speed drop. Now change the gearing until you get it to be atleast as high as it was with factory wheels.
Old Jan 7, 2007 | 03:46 PM
cradar69's Avatar
cradar69
Thanks for the help I will check into this. Do you have any suggestions for maufacturer and retailer who has the best price.
Old Jan 7, 2007 | 05:31 PM
dhag911's Avatar
dhag911
if you are going to change go with at least 4.56 if you dont do alot of interstate driving and you have a 302 i would think about 4.88.
If i ever go with a gear change i am definatly go with 4.10 but i probably going to go with 4.56 and i have 33" tires and a 302
